What is the approach to replacing the belt drive pulley on the Whirlpool duet dryer? Do I take the back off and replace the pulley with the motor in place? Do I have to pull out the motor?
Thank you.
Bob K.
THIS FORUM IS DEAD!!!!!!! |
The response is not helpful. The manual provided in the response does not address replacing the motor pulley. In my case, I have a broken pulley. the end of the pulley is broken off, so the belt comes off when the motor starts turning.
A specific question I have is how do I lock the shaft to remove the broken pulley? The manual shows putting a 7/8 wrench on the pulley to turn off the blower wheel, but the hex end of the pulley is broken off, and I don't want to remove the blower wheel.
Thank you.
Bob K.
I though you just wanted to know how to get at the motor. All I can suggest is using vice grips. Note that it may be reverse thread. Also perhaps the following will be useful. Click on the picture and then read the Q&A's Part number: AP5629873
Sorry...you're right, I didn't ask all the questions I had in my original post. I'll look for a flat spot on the shaft to grip with vise grips and allow me to turn off the broken pulley.
Thanks!
-Bob K.
