No water. Not sure if it is the PS2006979 limit switch which I cannot find or the water solenoid in the rear. The water works fine for the ice machine. I have access to the switch but do the have the service manual to diagnose the switch. Any idea where a switch can be foUND. I also notice the limit switch has two contact points. When I push one one I can faintly hear what sounds like a selenoid buzz Thanks
Groups: APP Team
Hi.
Looks like the model you provided is incomplete and we also need a serial and P numbers to look up the information for your refrigerator.
Thank you,
Simon.
Model #SRD26VPSE SERIAL #9904261449 MANU# P1315205WE I can access the switch, just don't know what voltages I should have. Is service manual available online? Thanks for your assistance! :)
