hubsta
#1 Posted : Friday, July 3, 2015 1:08:22 PM(UTC)
hubsta
Looking for a wiring diagram. Wondering if the defrost cycle is staying on but can't find a wiring diagram to see if defrost circuit is energized or not.
#2 Posted : Monday, July 6, 2015 11:22:00 AM(UTC)
Parts for KitchenAid KFIS29BBMS00 / - AppliancePartsPros.com
If stuck in defrost compressor, condenser/compressor fan and evaporator/freezer fan will all be off.
Have you tried unplugging it for a few minutes to see if it will reset itself?
File Attachment(s):
KFIS29.pdf (327kb) downloaded 14 time(s).
hubsta
#3 Posted : Tuesday, July 7, 2015 6:19:41 AM(UTC)
hubsta
Thank you for the tech sheets. I did have it unplugged for quite a while(several days). The components mentioned in denman's reply were all running when I was taking a look at it.
Maytag Fridge / Freezer not cooling at all (Refrigerator & Freezer Repair)
by tigerjim 8/30/2011 11:50:56 AM(UTC)
