my washer works fine when washing but sometimes it will not spin on the rinse cycle.any answers?:confused:
In order to provide the most accurate advise I need the complete model number of the washer.
i just had a similar problem and solved it.....look at my post for today and see if it helps you out. good luck
Originally Posted by: zamboy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) i just had a similar problem and solved it.....look at my post for today and see if it helps you out. good luck tonerman2010@aol.comany tips on going through field service modes?
