Joseph Tackett
#1 Posted : Monday, May 18, 2009 2:34:43 PM(UTC)
Joseph Tackett
We have a Whirlpool LER8648PW0, which is not heating. We have the back cabinet off and have taken the heating element out. The element does not look cracked, but does not heat outside of the cabinet either. How can we tell if this is an element issue or a thermostat that needs replaced?
#2 Posted : Tuesday, May 19, 2009 3:58:38 AM(UTC)
Replacement parts for WHIRLPOOL LER8648PW0 | AppliancePartsPros.com
Here is a wiring diagram
https://www.servicematters.com/d...0Sheet%20-%203979703.pdf
Not sure how you tested it outside the unit so cannot say if it is blown or not.
Get a meter and check them.
First though turn your breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Symptom is no heat. Better yet check that you have 240 volts at the plug.
