The touch panel selections will all change and light up when pressed BUT the start button, and the dishwasher wont start. could it be fuses? the whole control panel? how can i troubleshoot this problem. thanks
Remove the toe panel and look for an envelope with the tech sheets under the dishwasher (more likely on the right side). If it's not there then check inside the control panel. Perform the tests as described in the tech sheets. Here are the breakdown diagrams and Replacement parts for GE GHDA960K03BB | AppliancePartsPros.comGene.
I looked under the kick panel, and also the control panel for some tech sheets, i didnt see them. I've decided its either the control panel, or the module control. i cant find anybody that will test those for me. Theres no way to "jump" the switch on the control panel since its all electronic. At least i dont see how to. do you know of a way to test these 2 parts to see which one is the defective one?
Unfortunately it is impossible to find any GE technical information, like manuals or wiring diagrams, online. If you can order it from GE and post, it might help.
