washer don't take rinse cycle
That is not a valid model number, so in the absence of any information about which machine you have the likely suspect is the lid switch. Check it out, and if it is okay post with the correct model number and as detailed a description of what happens as possible. For example, does the timer stop and does the machine have the problem in all cycles?
