madonid@hotmail.com
#1 Posted : Saturday, June 27, 2015 9:34:02 AM(UTC)
madonid@hotmail.com
My dishwasher stopped drying dishes recently. When I examined it closely, I noticed that the heating element appeared to be cracked, so I ordered this one:
Whirlpool W10518394 Heater - AppliancePartsPros.com
I replaced the heating element but the dishwasher still does not dry. What else could be the problem?
I'm not the handiest man, so when offering troubleshooting advice, please be specific on what to do, (i.e. "look for a little square thingy just above the blue doo-hicky...") :cool: Thanks in advance...
#2 Posted : Sunday, June 28, 2015 12:31:11 AM(UTC)
Parts for Whirlpool WDF530PAYM4 / Dishwasher - AppliancePartsPros.com
Could be the high limit thermostat (item 15 in section 05).
It should be 0 ohms.
Next to check would be the wiring from the control board to the heater.hi-limit, then the temperature sensing thermistor.
If all OK then odds are the control board is bad.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
WDF530.pdf (875kb) downloaded 11 time(s).
madonid@hotmail.com
#3 Posted : Sunday, June 28, 2015 6:29:39 AM(UTC)
madonid@hotmail.com
Thanks for the prompt response! I'll follow your suggestions and see if I can spot the problem.
