The pivot pin on the ice dispenser paddle came out on one side and i removed the front panel and the ribbon cable pulled out of the control panel. I put the pivot pin back in and plugged the ribbon cable back in. no lights, ice or water working now. I have ordered a new ribbon cable. watched the replacement video. it shows just pull out on the ribbon cable to remove it from the power board. Mine is very tight and does not want to pull out. There are no visible tabs to release it from the power board like on the control board. How is this end of the ribbon cable removed?
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have a problem with my wiring ribbon harness from the interaction board and the cover board to the ice and water dispensers. The ribbon came out on the cover board and I do not know where to place the end into the board
