garyboz
#1 Posted : Friday, June 26, 2015 7:38:41 AM(UTC)
garyboz
On my Jennaire side-by-side refrigerator/freezer model #JSD2690HES the ice maker is stuck on the water setting. All three lights are on (water, crush and ice) but it only dispenses water and it won't switch to the ice or crush modes. I pulled out the ice maker and cleaned out all the ice and turned the lever at the back if the freezer that turns the feed mechanism. I'm not sure if it's making ice yet. I dumped the ice about a half hour ago and put the lever down but it hasn't made any ice yet.
Simon / APP Team
#2 Posted : Friday, June 26, 2015 10:13:01 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Based on the information you provided the control board inside the dispenser is shorted out. Also you need to check if the ice door stays open. There is an ice door solenoid inside the dispenser on the right and if it is damaged it may short the control board.
Here are the breakdown diagrams and parts list for your refrigerator:
Model JSD2690HES
Dispenser control board Part number: AP4077902
Good luck. Please, keep us posted of the results.
Thank you,
Simon.
