m cox
#1 Posted : Thursday, June 25, 2015 10:54:33 AM(UTC)
m cox
Previous threads state it most likely is my water inlet valve. My valve is a single valve with one water line connected. Can a single valve unit be bad in regards to no water going to the icemaker, but still send water to the door water system?
m cox
#2 Posted : Thursday, June 25, 2015 11:02:52 AM(UTC)
m cox
I have looked at the other threads for this problem and they show duel units. I understand if the icemaker valve goes bad how the other side for the door water can still function. But if a single valve goes bad would the door unit not be disabled as well?
Guest (4)
