Icemaker not cycling. Took apart motor runs. when freezer door open ice control flashes 2 times, close ice bin emitter door light steady. close door switch no light. Uplugged once then unit started after being unplugged to verify motor. Unit tines went around, filled with water but now will not eject ice as tines do not start. Help!
