jb35007
#1 Posted : Tuesday, June 23, 2015 7:53:23 AM(UTC)
jb35007
i have a haunting f1 code i have replaced the control board and both relay boards..
oven seems to work fine except after a few minutes of not being used it starts beeping with f-1 code
next thing i'd like to check is the temp sensor? not sure if i got the right part i grabbed the thermal switch on top of the oven but im not sure if that is the part i need to look at?
i'm thinking the oven doesn't register room temp? as i get no error codes if i am using the oven? not sure as i swapped out the expensive crap already and still getting same code !@#$%^
someone please help point me in a direction of hope...
o and the thermal switch offers 0 resistance at room temp and the reset switch seems to work ok.
jb35007
#2 Posted : Tuesday, June 23, 2015 8:13:37 AM(UTC)
jb35007
temp probes give me 1092 top oven and 1048 bottom oven so i guess it isn't that!@#$%
jb35007
#3 Posted : Tuesday, June 23, 2015 8:13:39 AM(UTC)
jb35007
Simon / APP Team
#4 Posted : Tuesday, June 23, 2015 4:41:02 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
I'm afraid the control panel/touch pad for your oven is no longer available.
Control panel Part number: 318030135
Thank you.
Simon.
jb35007
#5 Posted : Wednesday, June 24, 2015 6:09:55 AM(UTC)
jb35007
i already changed the control board....
jb35007
#6 Posted : Wednesday, June 24, 2015 6:10:33 AM(UTC)
jb35007
Simon / APP Team
#7 Posted : Wednesday, June 24, 2015 9:00:51 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
I was referring to the control panel (touchpad), not the control board.
Thank you,
Simon.
jb35007
#8 Posted : Wednesday, June 24, 2015 11:32:13 AM(UTC)
jb35007
that is what i changed and i also had the relay boards checked out
Simon / APP Team
#9 Posted : Wednesday, June 24, 2015 12:07:38 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you don't mind, please, give me the part numbers of the controls that you have replaced.
Thank you,
Simon.
