I followed your instructions and the result was a complete success! Thanks so much for your invaluable expert advice. Couldn't have done it without this site. Juliusz
Hello,
I have a similar problem, but only the left front XLO burner does not ignite. It does not get any gas flow. I replaced the parts that you referenced above, but am still having the same issue.
What other options do you recommend? Could the valve be bad, or perhaps the solenoid? How would I troubleshoot to determine which one?
