JR2015
#1 Posted : Monday, June 22, 2015 10:23:16 AM(UTC)
JR2015
I have a Crosley CAW9244XQ1 that stopped going into spin and drain. The lid light comes on. The lid does lock when I try to start it up. It doesn't make any sounds like it's trying to start.
I get the following fault codes: F5 E1, F8 E3, F8 E5, and F9 E1.
I checked the lid switch continuity with the following results: Lid Open - Yellow and White closed, Lid Closed - Yellow, Blue, and White closed. Nothing on the Red wire.
I'm not sure if it's the Lid Switch with all the fault codes and continuity with the lid open and closed. Is there anything else I can check or do? Thank you in advance for any help.
Simon / APP Team
#2 Posted : Monday, June 22, 2015 12:15:15 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
How did you get all of this fault codes? According to codes you have got there the lid switch, the overflow, the hot/cold hoses switch around and on the top of it the long drain problem!!! I can't believe it's possible unless the main control board has gone mental:) Unplug the washer for a few minutes to reset the control. Check the wire harness and connections at the control board.
Here is the control board Part number: AP5272946
Good luck. Keep us posted please with the results.
Thank you.
Simon.
JR2015
#3 Posted : Monday, June 22, 2015 12:53:06 PM(UTC)
JR2015
I followed your instructions and now the only fault I am getting is F5 E1. Thanks for your help. I'm going to order a new Lid Switch and it should be as good as a used washer.
Simon / APP Team
#4 Posted : Monday, June 22, 2015 1:46:58 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Here is the lid lock assembly for your washer Part number: AP5263307
Click on the picture to get the repair video.
Thanks.
Simon.
Guest
#5 Posted : Saturday, July 3, 2021 3:06:54 PM(UTC)
Guest
Rank: Guest
United States
Help! I have a rather newer crosley top loader entirely digital displaying f5 and beeping Wont come on. Even saw an e3 on it
