ctepen2
#1 Posted : Sunday, June 21, 2015 12:16:27 PM(UTC)
ctepen2
Hey all - I am brand new to this forum, so I apologize for any mistakes in etiquette I make (or have already made ...)
I have an older model Whirlpool (I bought it used, so I'm not exactly sure of the age). I replaced the clutch about a year and a half ago because it wasn't spinning out all of the water. Now, the "normal" wash cycle will start and agitate, but it doesn't seem to be draining or spinning. The "permanent press" and "delicates" cycles seem to work fine. Do y'all have any suggestions?
I am video recording a cycle right now, so I'll update later with exactly what is going on with the cycle when I find out.
Thanks!
ctepen2
#2 Posted : Sunday, June 21, 2015 12:25:15 PM(UTC)
ctepen2
Alright everyone - I just watched the video.
It seems as though the tub will fill with water and agitate, but it will not spin out, or do anything else in the cycle after that - it just times out. I did check again, and the post-agitation spin is operating properly in the permanent press cycle. I'm not sure what could be causing the problem, but do these symptoms imply, at least, that it's not the clutch?
fairbank56
#3 Posted : Sunday, June 21, 2015 3:25:57 PM(UTC)
fairbank56
Groups: Expert
That's a 94 model. Sounds like a faulty timer.
Whirlpool 285938 Timer - AppliancePartsPros.com
Eric
