The broiler turns on in 70 seconds. The oven does not go on. The ignitor does not heat at all when the oven is turned on. The burners work. The clock works. When I push the button on the control panel to turn on the oven I heard a couple of click nosies as if something was starting to work but nothing happens. No codes come up on the control panel. Thank you.
you likely need to replace the carborundum igniter for the oven..
Originally Posted by: Teacher Jim  you likely need to replace the carborundum igniter for the oven.. This is a tenant stove so I am not positive on how it works, but from visual inspection and the diagrams, it looks like there is only one igniter and one burner fro both the broiler and the oven. Since the broiler turns on in the "correct" amount of time and the igniter has no glow at all when the oven is turned on it seems to me, who knows next to nothing about this, that is something else, like a switch. Can you explain your reasoning for changing the igniter? According to the diagram on this site, the igniter is by Frigidaire Part Number AP2150412. Is that what you are talking about? Thank you.
