For the last couple of days I've been observing a mysterious power draw on my refrigerator: (see attached file if this URL doesn't resolve) Every 10 minutes something starts up, draws about 100W for 5 minutes, and shuts down again. This happens continuously 24h. The compressor cycle is working fine and the fridge is holding the temperature fine. I can't see any obvious problem. Any ideas on what might be causing this? I'm worried that whatever component this is, continuous use will cause it to fail. patrickmann attached the following image(s):
