jmeag
#1 Posted : Tuesday, June 16, 2015 4:51:28 PM(UTC)
jmeag
We have determined that thermostat is the cause of our problem, when we opened and installed the new one it appears there has been a design change. the wire leads were stacked on the old one. they are side by side on the new one. how do we know which wire goes where ?
Thank you !
#2 Posted : Wednesday, June 17, 2015 2:24:11 AM(UTC)
I am assuming this is a two wire thermostat so it does not matter which wire goes to which connector.
If there is a third wire *(white) then that may have to be attached to the body of the thermostat.
slmas143
#3 Posted : Sunday, May 22, 2016 6:30:47 AM(UTC)
slmas143
bot how do i do it if it's in a black box?
Do i have to cut the wires?
