wellerons
#1 Posted : Tuesday, November 13, 2012 11:29:41 AM(UTC)
wellerons
My Whirlpool Duet Stem Dryer powers on and when you press the start button, you get a click, and then it sits for about 30 seconds then you get another click and it diplays an F01 error. I turned off power at the circuit breaker for 30 minutes and turned it back on and the symptoms remained the same. I even read in one forum to diconnect the P4 plug from the control board that is mounted on the top of the dryer with the relay that clicks and then plug it in with the power off to just get it jump started and that did nothing either. I dissembled it following structions I found here and see the white module that is attached to the top crossmember with the relay that clicks and then opened up the front to expose the electronics control module assembly. Much to my surprise since I couldn't find the exact moddel I have on here it has 2 circuit boards in there. So now I am what as far as I can tell 3 possible options for the failure and no way to determine which one it will be. Any assistance would be greatly appreciated.
#2 Posted : Wednesday, November 14, 2012 1:14:38 AM(UTC)
Parts for Whirlpool WED9500TW1 Dryer - AppliancePartsPros.com
The error points to the electronic control board (item 40 in the Cabinet Parts section).
[COLOR="Blue"]
Much to my surprise since I couldn't find the exact moddel I have on here it has 2 circuit boards in there. So now I am what as far as I can tell 3 possible options for the failure and no way to determine which one it will be.[/COLOR]
I do not understand what the above means.
File Attachment(s):
WED9500.pdf (520kb) downloaded 41 time(s).
sjl127
#3 Posted : Sunday, June 14, 2015 4:38:49 AM(UTC)
sjl127
Originally Posted by: denman Go to Quoted Post
[COLOR="Blue"]
Happend to me, here's the part and what it looks like underneath.
The relay "fried."
I wonder why?
sjl127
#4 Posted : Sunday, June 14, 2015 4:46:56 AM(UTC)
sjl127
The relay "fried."
I wonder why?
See the pictures.
sjl127 attached the following image(s):
