behrgood
#1 Posted : Sunday, May 17, 2009 2:00:48 PM(UTC)
behrgood
My Maytag quiet series 100 fills with water sounds like its running through the wash cycle then drains but dishes dont even seem like they got wet.
#2 Posted : Sunday, May 17, 2009 3:55:05 PM(UTC)
Perform the troubleshooting as described in the Service manual.
Here are the breakdown diagrams and Replacement parts for MAYTAG MDBTT59AWW | AppliancePartsPros.com
behrgood
#3 Posted : Sunday, May 17, 2009 4:25:52 PM(UTC)
behrgood
i have the use and care guide and have gone through the trouble shooting section but there is no subject that describes my issue.
#4 Posted : Sunday, May 17, 2009 4:29:54 PM(UTC)
The "Use and Care guide" and the "Service manual" are very different. The first things I would check are the water level and the wash pump.
ejg593
#5 Posted : Monday, May 18, 2009 4:45:15 AM(UTC)
ejg593
When I posted back in 07 & I was told it was still under warranty, I called the 1800 number. They confirmed it was under warranty & sent out a technician. He diagnosed it w/his laptop as a problem w/the upper side of the motor, ordered a new motor & came back a week later to install. But the same problem was happening. Thistime, the laptop said it was a problem w/the lower side of the motor. He called in a 2nd tech & after they messed w/it all day, swapping parts, hooking up laptops, etc- they discovered the mother-board was shot....which isn't under warranty. A new one would cost more than a whole new dishwasher. They took the new motor back, I recycled the old dishwasher & bought a new one. Good luck man.
