I have a top Load washer that does not complete the spin cycle. and the lid and light blinks.
We replaced the lid lock sensor but it still not completing the spin cycle. and the clothes ends up too wet to put in washer. I can put on drain and spin cycle but it doesn't always complete as well.
Groups: APP Team
Hi.
In order to assist you we need a complete model number of the washer.
Thank you.
Simon.
Groups: APP Team
Hi. Does the washer drains the water and starts spinning and then stops and "lock" LED flashes? If that is correct, the lid lock assembly should be looked at. If you already replaced the lid lock assembly, check the lid strike condition. Using a multimeter you may also check the lid switch and lock switch for continuity at the control board disconnect plug. Go to a four wire plug at the control. With the lid closed and locked you should have continuity between RED and WH and between BLUE and WH. If both has continuity and the harness and plug are good, then most likely you should replace the control board. Main control Part number: AP5263416
Here are the breakdown diagrams and parts list for you washer Model WTW4850XQ0
Thank you. Simon.
