jdman
#1 Posted : Sunday, July 29, 2007 2:53:42 PM(UTC)
jdman
Breaker trips after running electric dryer 8-10 minutes. Have taken panel off and no burnt or broken wires. Have tested parts and all are good. Checked element and continuity through it and removed it and all looks good. Had electrician change to different breaker in box and still the same. Any ideas on problem? Thanks
ApplianceJunk
#2 Posted : Tuesday, July 31, 2007 5:29:03 PM(UTC)
ApplianceJunk
Hi jdman!
Bumping to the top.. :)
jdman
#3 Posted : Friday, August 3, 2007 9:32:01 AM(UTC)
jdman
Problem solved. Found that when dryer was wired from unit to breaker box someone didn't have enought wire to mak the run I guess and had spliced wire to complete job. Replaced wire and all is fine. It's amazing what folks will do.
#4 Posted : Saturday, August 4, 2007 6:53:44 PM(UTC)
jdman
Good job man!
Odd Kenmore Dryer Model number (Dryer Repair)
by adamm53 3/2/2024 3:42:02 PM(UTC)
Kenmore Dryer blowing thermal fuses (Dryer Repair)
by Marius 11/21/2023 2:26:28 PM(UTC)
Kenmore Dryer stops running after start button is released (Dryer Repair)
by Jbee14 7/30/2023 11:15:53 AM(UTC)
Kenmore Dryer spinning cold air nonstop until the door is open (Dryer Repair)
by Guest 5/15/2023 10:22:27 AM(UTC)
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 4/18/2023 3:58:41 PM(UTC)
Kenmore dryer issue when heat is on (Dryer Repair)
by Guest 2/2/2023 2:17:08 PM(UTC)
Kenmore Dryer Model:86984110 (Dryer Repair)
by CarolynC143 10/23/2022 5:00:36 AM(UTC)
Kenmore dryer help Elite HE3 (Dryer Repair)
by Guest 5/5/2022 8:17:09 PM(UTC)
Repair manual for Kenmore dryer model 110.85081401 (Washer Repair)
by Guest 5/5/2022 2:29:52 PM(UTC)
kenmore dryer wiring (General Talk)
Belarus epyveras 3/24/2022 7:04:26 AM(UTC)
KENMORE DRYER WIRING 796.813 (Dryer Repair)
by Guest 3/24/2022 7:00:58 AM(UTC)
Kenmore Dryer Model 110.76752500 Parts (Dryer Repair)
by redknitter 2/23/2022 7:24:03 AM(UTC)
kenmore dryer powers up with lights on, push start and it chirps and that is all (Dryer Repair)
by Guest 10/14/2021 7:53:03 PM(UTC)
Kenmore Dryer 41790052990 (Dryer Repair)
by Guest 3/26/2021 4:59:53 PM(UTC)
Kenmore Dryer Timer Power Resistor Rating (Dryer Repair)
by mhall264 3/19/2021 9:04:39 AM(UTC)
