davidsg99
#1 Posted : Monday, June 1, 2015 9:07:15 PM(UTC)
davidsg99
My washer only spins on high speed no matter what you do. Also, it is really loud when spinning. It has never been this loud. I can hear it upstairs when it is going. Every once in a while it gets stuck and you have to turn the drum inside so it will go.
I thought I had the solution of replacing the gear underneath it. But that's if it gets stuck only. Nothing about the speed and noise. It may be the same problem but not sure. Don't want to order the parts until I know which to really order.
Help would be appreciated.
davidsg99
#2 Posted : Monday, June 1, 2015 9:09:45 PM(UTC)
davidsg99
Thanks for the assistance!
I accidentally left this reply. I still need help.
fairbank56
#3 Posted : Tuesday, June 2, 2015 6:41:52 AM(UTC)
fairbank56
Groups: Expert
Model number???
