herkyfred
#1 Posted : Sunday, May 17, 2009 11:35:17 PM(UTC)
herkyfred
:mad:the timing mechanism for the dryer seems off. Certain settings do not end when they should, extending the drying time too long.
#2 Posted : Monday, May 18, 2009 12:34:42 AM(UTC)
Probably warped contacts in the timer if the knob is not loose on the shaft. If the timer contacts are visible, you should be able to adjust them, if not, new timer time. AP3995347
#3 Posted : Monday, May 18, 2009 12:49:24 AM(UTC)
Model Search
By the above do you mean that Timed Dry runs OK but Auto cycles never shut off?
