Hi, I have a whirlpool resource duet front loading dryer. My safety control lock seems to be locked. I hold it for 3 sec and nothing happens, however if I slightly hit it the light goes off and then I can slight hit it and it comes back on, but its still in lock mode. When I turn the dryer off and try to put it in lock mode it works and I can unlock it.. when I try and start my dyer is just beeps. I have replaced the control panel boad and main control board and neither fixes the problem. The theremafuse has been replaced as well. any idea before I have to buy a new dryer
Groups: APP Team
Hi, k62254. Did you try to replace the console assembly, not just the control board inside it? The console assembly Part number: AP4500422
Thank you. Keep us posted. Best, Simon.
No I did not try that part because it didn't seem like that would be the issue because it's just plastic I guess I'm wrong on that? Could just that plastic part really be the issue and not the control panel behind it
Groups: APP Team
Hi. In your case we need to check all the options. Also, I would check all harness wires and connectors between those two controls.
Best,
Simon.
Would it make a difference if I ordered the electronic board with a new plastic cover? Or can I order just the plastic cover and attach my electronic board to it?
Groups: APP Team
i don't see the cover being sold by itself. And again, I'm stressing out that the wire harness should be checked.
Best,
Simon.
