Biddy
#1 Posted : Friday, May 29, 2015 9:26:14 AM(UTC)
Biddy
I need help getting to heating element I have taken off all the screws on back but it appears to be welded on. The back doesn't just come off like most dryers.
fairbank56
#2 Posted : Friday, May 29, 2015 9:44:51 AM(UTC)
fairbank56
Groups: Expert
There is no rear access on your dryer. Remove the front toe panel for access to the heating element.
Eric
Biddy
#3 Posted : Friday, May 29, 2015 11:15:58 AM(UTC)
Biddy
Thank you very much for quick response. I kept thinking I had to be missing something because first video I watched showed rear access. I kept looking and scratching my head because I could see weld marks without taking screws out. Have located lower door. I ordered heating element according to that video but will now check some other things before I put it on so that I can return it if not needed. Thanks qgain
