The refrigerator door makes popping sound when opening and closing
The refrigerator door makes popping sound when opening and closing the door
Groups: APP Team
Hi, John. In your case the problem is, most likely the worn out door cam(s). They are located at the bottom of the door and on the door hinge. Replace both of them at the same time. The door cam for your model is Part number: AP3046922
. The part number for the kit is Part number: 4318165
. If you click on the first part you will be able to watch the video with installation instructions. If you' ll have any questions, please let me know. Thank you. Simon.
