vdokka
#1 Posted : Friday, May 22, 2015 7:02:43 AM(UTC)
vdokka
KXD4636YSS0 downdraft vent does not come up at all. Here is what happened.
1. I pressed the top switch, downdraft started coming up.
2. Before it settles down, I removed one of the filters for cleaning. Suddenly it started going down by itself.
3. It went down and has only 1 filter inside, does not come up now even after pressing the button multiple times.
Did the button go wrong?
Is the switch circuit not complete with only 1 filter left inside?
How Do i bring up the downdraft vent to put back the filter?
Any help is greatly appreciated.
vdokka
#2 Posted : Friday, May 22, 2015 7:14:01 AM(UTC)
vdokka
Can I manually try to PULL UP the downdraft vent after removing the top cover?
