Hello, I will start at the beginning. My icemaker was jamming intermittently and I had to un jam the cubes once a week. Then this time, after an un jam, water was running everywhere from the icemaker. I was unable to move the ice maker bale all the way up or down, it only moved about ½ inch. After removing the icemaker I noticed the motor/pawl/cam whatever it’s called was out of phase with the motor which is why is couldn’t move up or down. I replaced the icemaker with a direct replacement, since then nothing happens at all, totally dead, no water, no ice, no nothing. I also after this replaced the fill valve, no change. I have good water pressure going to the valve. I did let the new ice maker acclimate for a few days …no change. I checked for AC voltage between points Y and N with the door switch closed and got nothing there. I am stuck at this point. Amana Arb2217cc Parb2217cc0 Thanks, Greg
