jfoxarnold
#1 Posted : Saturday, May 9, 2015 11:30:40 PM(UTC)
jfoxarnold
Hey guys, I have a GE electric dryer that is probably a little over ten years old. It makes this horrible squeaking noise w/ every rotation. I was wondering if there is a grease fitting that needs attention or if anyone might know how to make it a squeakless laundry experience. Any knowledge would be appreciated.
#2 Posted : Wednesday, May 13, 2015 3:02:19 AM(UTC)
Parts for GE DVL223EB1WW Dryer - AppliancePartsPros.com
Could be a bunch of things so you will have to open the unit up to find the cause.
The most common cuase in these units is a dried out or worn rear drum support bearing.
If it needs re-lubing be sure to use a high temperature grease.
Could also be the front drum support, belt idler wheel or motor bearings.
This is agood time to also check other internal parts and give it a good cleaning.
I would also check/clean the vent system.
Maytag Dryer- making horrible squeaking/squeeling noise (Dryer Repair)
by Phillady1 5/23/2011 6:50:44 AM(UTC)
