tkt2ride
#1 Posted : Tuesday, May 12, 2015 11:20:34 AM(UTC)
tkt2ride
The fan blade got blocked by insulation crimping up when we moved the fridge. The condenser, of course got very hot. Waited for it to cool completely. Replaced relay & overload. Has power to lights inside, but no power to fan or condenser. Fan & condenser have continuity.
:confused:
#2 Posted : Wednesday, May 13, 2015 2:47:23 AM(UTC)
Parts for Whirlpool ED25PQXFW01 Refrigerator - AppliancePartsPros.com
See the attachment for the tech sheet,
Does the evaporator/freezer fan run.
If yes then it is probably a wiring/connector problem as the two fans and the compressor all run at the same time (wired in parallel).
How much time have you given it.
Give it at least half an hour as you may be in a defrost cycyle.
Could be you are stuck in a defrosr cycle.
Rotate the timer cam to see if that will end the defrost.
If yes then replace the defrost timer as ity is not advancing.
Coulds also be the main temperature control thermostat.
File Attachment(s):
ED25PQ.pdf (157kb) downloaded 8 time(s).
tkt2ride
#3 Posted : Wednesday, May 13, 2015 4:32:49 AM(UTC)
tkt2ride
The Fridge was in defrost cycle. Talked to Cust. Service/Tech and I rotated timer and it started right up. Working perfectly this AM. EXCELLENT service from this company!!! :):):)
tkt2ride
#4 Posted : Wednesday, May 13, 2015 4:54:29 AM(UTC)
tkt2ride
Now that the refrigerator is working again, is there a "default" setting for the rotation of the defrost timer? I rotated it to get it running and want to make sure it is reset correctly.
#5 Posted : Thursday, May 14, 2015 2:02:46 AM(UTC)
There is no default setting.
The timer cam rotates all the time.
tkt2ride
#6 Posted : Thursday, May 14, 2015 4:30:11 AM(UTC)
tkt2ride
Oh... I get it! I thought the cam was a potentiometer. Duh...
Thanks for your good advice Denman.
You guys rock!!!:):):)
