Dryer produces heat, but does not dry the clothes. No lint gets to the filter screen. The coils have been replaced, but same problem exists. It seems that no air circulation is getting to the clothes and filter screen. Any ideas? Thanks
It is almost certain that the problem is that air is not flowing through your dryer. There can be two reasons for this
1. The blower fan is not operating. This can be checked by taking off the blower fan cover and briefly turning on the machine.
2. There is an obstruction (clothes, lint, something else) in the venting duct system. This is the most likely problem, and you need to make certain you have cleaned out the system. Take it apart as much as you can and use a vac or air hose to clean it out.
Good luck, and let us know how it turns out.
