thildy
#1 Posted : Thursday, May 7, 2015 2:26:44 PM(UTC)
thildy
My dryer will not heat up in the timed dry mode, auto dry mode works fine. I have replaced the thermostat and thermal cutoff and also went ahead and threw in a new heating element
fairbank56
#2 Posted : Thursday, May 7, 2015 3:29:40 PM(UTC)
fairbank56
Groups: Expert
Piece of junk timer is used in this model. Very high failure item.
Whirlpool W10185982 Timer - AppliancePartsPros.com
Eric
Sphere478
#3 Posted : Thursday, May 7, 2015 6:25:22 PM(UTC)
Sphere478
Unusual problem.. Yeah, my thoughts are with the timer as well. Those are easy to take apart to insoect the contacts. Sometimes they can even be cleaned if they aren't blown out.
fairbank56
#4 Posted : Friday, May 8, 2015 5:00:42 AM(UTC)
fairbank56
Groups: Expert
Not worth the effort to try and repair this type of timer. They are absolute junk. Used on low end dryers and fail all the time.
Eric
