bbell69
#1 Posted : Thursday, May 7, 2015 4:11:40 AM(UTC)
bbell69
I have a Whirlpool built-in oven Model #RBS275PDB14. The problem is the oven overheats as if it were in the cleaning mode. The door locks and have to flip the breaker to shut it off. Two codes come up: E2 and F3. Could it be the thermal sensor?
Jeff / APP Team
#2 Posted : Thursday, May 7, 2015 6:04:25 AM(UTC)
Jeff / APP Team
Hello Bbell69. 1.Check sensor connection.
2.Measure sensor resistance (1080Ω at 70° F [21° C]. Add 2Ω
per degree F).
3.If resistance is not valid, replace sensor.
4.If sensor resistance and connections are good, then check for
welded-closed relays on the control. You can test this with a multi-meter AP3873826. Here is a link on how to use a multi-meter. http://forum.appliancepartspros...continuity-ohmmeter.html
