Hello.,
I have a Kenmore Gas Dryer – Model: 77832791 – 77832 The flame stays on for 10 seconds and then goes out. I have changed the Solenoid Coils and the flame will light, but still goes out after 10 seconds. Then, a minute or two later the ignitor glows again and the flame starts, then, goes out after 10 seconds. I also ran the Dryer with the vent system disconnected. Cleaned the vent system reconnected it and still the flame goes out after 10 seconds. Any ideas..?? What do you suggest I try next? Thanks so much! Joe from Chicago
Hello Joeguy. If the coils are new and the issue continues, you will need to make sure the wiring to the coils are good and if so, replace the gas valve assembly on the unit.
