Pjrs
#1 Posted : Sunday, May 3, 2015 9:42:02 AM(UTC)
Pjrs
Hello, recently the freezer started to build ice in the drain tray where it eventually builds up that the drain hole eventually plugs and it runs into the bottom of the freezer.
I have cleaned it up thinking it was just a plugged drain hole, and did find a piece of plastic, however this was not the case as it keeps coming back.
Here is a picture of it 24 hours later you can see the pieces of ice forming on the drain tray and the drain hole is clear as I can run water through it.
Everything else seems to be working well, fridge is cold and ice maker is working well.
You folks were wonderful last time and any ideas are greatly appreciated.
Pj
Pjrs attached the following image(s):
UncleRodge
#2 Posted : Sunday, May 3, 2015 1:31:50 PM(UTC)
UncleRodge
Those pesky defrost drains do get clogged up at times. If you only removed the plastic, you may not have gotten it completely de-clogged. I use a turkey baster and hot water to flush that sucka out. Works everytime!
Hope that helps!
Rodge @ Flipping Appliances On a Shoestring Budget
Pjrs
#3 Posted : Sunday, May 3, 2015 4:28:37 PM(UTC)
Pjrs
Thank UncleRodge, already did that and the water drains no problem. It is when you restart the freezer you can see the ice is forming before it even has a chance to drain. ;-(
#4 Posted : Monday, May 4, 2015 2:50:52 AM(UTC)
Check the freezer temperature.
It should be between 0 and 5 degrees F.
Could be it is too cold so the water freezes before it can drain.
Check that the drain tray is nice and clean.
Also sometimes a buffed up coating of wax will help the water to drain faster.
If all else fails get a length of 10 or 12 guage wire wrap it a couple times around the defrost element and then down the drain an inch or two.
\Wrap ity snug but not super tight.
Also a good idea to force a defrost cycle to check that it does not get too hot.
Below is a more elegant part that does the same thing.
Click on the picture to get more info on it.
Part number: AP3119957
Pjrs
#5 Posted : Monday, May 4, 2015 7:42:12 PM(UTC)
Pjrs
Hi Denman, this is definitely a great fallback to try and fix the issue. However, what is driving me crazy is it worked perfectly for 10+ years and now it is having trouble.
I am wondering if it is the heater coil not staying warm enough or the timer cycle not allowing enough time to probably defrost.
In the end there should be a reason why this is happening...
Thanks for your advice it is truly appreciated.
Pj
#6 Posted : Tuesday, May 5, 2015 3:49:58 AM(UTC)
Yes there should but I do not know what the reason is.
I can tell you that the symptoms and time line you refer to is basically the same as others who have posted but I have never seen a post that said they found the cause.
Either of the causes you give could cause the problem.
There is also a possibility that the freezer is getting too warm occasionally and water is dripping down onto the pan.
To check for this put a bowl of ice cubes in the freezer.
Leave them here a couple days then if they are all frozen together you know the freezer got too warm.
Also it is possible that a piece of foam etc. by the evaporator coil has come loose and fallen etc. so that the air flow in that area has changed.
