maytagfrustration
#1 Posted : Monday, May 4, 2015 7:39:37 PM(UTC)
maytagfrustration
my wife and I remodeled our laundry room. I moved our maytag bravo washer and dryer out into the garage and when I finished remodel, I brought them back into laundry room and now the washer throws up error code f51...it was working just fine when I moved them out of room. PLEASE HELP!!! I have taken it apart 2 times now and can find nothing wrong.
Jeff / APP Team
#2 Posted : Tuesday, May 5, 2015 8:42:20 AM(UTC)
Jeff / APP Team
Forum Rank:: Advanced Member
Hello. Check for a loose or bad wiring connection on the unit. Make sure you check the RPS sensor good. If all wires and connections are good, you will need to replace the RPS sensor and wiring harness on the unit.
