den6200
#1 Posted : Sunday, May 17, 2009 6:11:43 AM(UTC)
den6200
My electric dryer heating element continues to heat after the motor has stopped. It is my understanding that this is caused by a faulty centrifical switch which should open the electrical path to the element when the motor is idled. In viewing the electrical schematic I do not see an external switch, however, within the motor it appears two switches are present. The m1 and m2 terminals appear to be connected to the element. Is this a replaceable? Or must the motor be replaced?
#2 Posted : Sunday, May 17, 2009 8:06:02 AM(UTC)
Model Search
Unfortunately the motor has to be replaced.
Jim-MRA
#3 Posted : Sunday, May 17, 2009 8:15:25 AM(UTC)
Jim-MRA
This could also be a shorted heating element ! If the element is grounded to the case and the timer is in the on position the element will stay hot when not running.
#4 Posted : Sunday, May 17, 2009 8:42:12 AM(UTC)
I should have thought of that, sometimes I must be wide asleep.
Jim's suggestion is a high probability, because if the heater was on full with no air movement it should blow the thermal fuse.
