good used stuff
#1 Posted : Friday, April 24, 2015 10:48:50 AM(UTC)
good used stuff
I have changed the run capacitor and overload. The fridge and freezer does not cool at all. The display will not stay set on the readings.. I put the fridge on 38 and the freezer on 0 but they change in to different settings in about 10 seconds. Is this a control board?
#2 Posted : Saturday, April 25, 2015 3:27:59 AM(UTC)
Parts for KitchenAid KBFS25ETSS00 Refrigerator - AppliancePartsPros.com
Here are the manuals
http://www.whirlpool.com/webapp...gId=-1&storeId=10211
I am not sure that there is a problem with the display.
The way I interpret the operators manual is that the display will change to show the actual temperature shortly after you adjust it.
If the compressor is running and the unit is not cooling then it is probably not a control problem.
