APPLIANCEDUDE1972
#1 Posted : Wednesday, April 22, 2015 4:05:46 PM(UTC)
APPLIANCEDUDE1972
Ok after the spin cycle the clothes are still wet, ringing wet. I changed the clutch assembly, which didnt help, i also changed the water pump. They are still needing 2 spin cycles or more to be like normal. I checked the flow and its good, i also pulled inmer basket and there is nothing in drain hole. What else is there? I checked the brake tube ends and they were fine and the block was fine too. If the brake tube is bad on the bottom how can I tell? This one jad got me really stumped!!!
jehu25
#2 Posted : Thursday, April 23, 2015 9:32:43 AM(UTC)
jehu25
Is this a whirlpool direct drive?
APPLIANCEDUDE1972
#3 Posted : Thursday, April 23, 2015 11:39:18 PM(UTC)
APPLIANCEDUDE1972
Yes kenmore, it was the brake tube, i had a spare, put it in and no issues, i still dont know why though, brake pads looked fine and so did spring, what am i missing
