i have a maytag wc202 that drains , but doesn't seem to drain completely. there is always water left over in the drain and strainer area of the bottom the tub . everything else seems to work fine. when the cycles are done there is still water in that area . doesn't seem to matter what cycle is used . thanks in advance for any advice.
