naabemgr
#1 Posted : Saturday, April 18, 2015 4:38:42 AM(UTC)
naabemgr
I purchased a bottle of transmission lubricant (6-0560800) from Applicance Parts Pros and the label has different capacities for a couple of Maytag washer models. I have a model number LAT9520AAQ--can someone please tell me the correct amount of fluid to refill? The last thing I want to do is overfill this unit. Thanks for your help!
naabemgr
#2 Posted : Saturday, April 18, 2015 10:50:05 AM(UTC)
naabemgr
It is either a large or small helical, or a dependable drive. Large and dependable use 34 ounces, small uses 26 ounces.
fairbank56
#3 Posted : Saturday, April 18, 2015 10:53:05 AM(UTC)
fairbank56
Groups: Expert
With transmission laid horizontal and cover removed, add oil til the level reaches just below the edge of the casing. Install cover and your good to go.
Eric
naabemgr
#4 Posted : Sunday, April 19, 2015 6:58:04 AM(UTC)
naabemgr
Thanks for the response. Uses full 34 ounces.
Guest (4)
