Washes fine untill it comes to the spin cycle,it makes noise and will not kick in . When the knob is pushed in and then turned back on ,it will then go into spin cycle.:confused:
Groups: Expert
This washer has a neutral drain transmission. After agitation stops, the washer should go into drain, without spinning, for a full 2 minutes. After the 2 minute drain period, the motor should stop for a few seconds and then start again. This takes the transmission out of neutral. At this point, it should start to spin while continuing to drain. If there is no motor pause after the 2 minute drain, the timer is faulty. You are pausing the motor when you turn the machine off and back on again which shifts the transmission out of neutral. If there is a pause after the drain period, but it still won't go into spin unless you manually pause it again, the transmission is faulty.
Eric
Originally Posted by: fairbank56 This washer has a neutral drain transmission. After agitation stops, the washer should go into drain, without spinning, for a full 2 minutes. After the 2 minute drain period, the motor should stop for a few seconds and then start again. This takes the transmission out of neutral. At this point, it should start to spin while continuing to drain. If there is no motor pause after the 2 minute drain, the timer is faulty. You are pausing the motor when you turn the machine off and back on again which shifts the transmission out of neutral. If there is a pause after the drain period, but it still won't go into spin unless you manually pause it again, the transmission is faulty.
Eric Just put in the timer and the damn thing works great. Thanks to Eric mama is happy, and when mama is happy...................Mike
