davidwhop
#1 Posted : Tuesday, April 14, 2015 7:36:22 PM(UTC)
davidwhop
My in wall frigidiare oven isn't heating like it should. Both elements will make heat but sometimes it seams to heat better than other times. It's even at times not wanted to heat at all and you would hear a lot of clicking coming from the control board. Seams that if you turn the breaker off for a few minutes and then back on it will start back heating but not as it should. As I said both elements make heat and when on broil the top element will turn red. Does this seam like a bad control board or maybe a heat sensor ?
davidwhop
#2 Posted : Friday, April 24, 2015 2:37:15 PM(UTC)
davidwhop
Any ideas ???
#3 Posted : Saturday, April 25, 2015 3:08:46 AM(UTC)
Sounds more like a control board problem.
When the oven is off the board should not be making clicking sounds and the oven sensor cannot make it do this.
davidwhop
#4 Posted : Sunday, April 26, 2015 4:07:27 AM(UTC)
davidwhop
The oven is on when the clicking is present. As I said it seams to hear better some times more than others and the clicking is usually when it's not heating well.
#5 Posted : Sunday, April 26, 2015 5:59:20 AM(UTC)
I still think it is a board problem.
They are usually the cause of intermittent problems.
davidwhop
#6 Posted : Monday, April 27, 2015 12:57:29 AM(UTC)
davidwhop
Ok thanks. I guess I need to find the model number and get one on order
