gdmayf@yahoo.com
#1 Posted : Monday, April 13, 2015 10:31:41 AM(UTC)
gdmayf@yahoo.com
No heat--replaced the hi-limit and 250 degree thermostats--fixed. Then the insulation/wire was melted off one of the heater terminal wires.
I replaced the damaged wire and it worked for a week. Then I had to replace the fuse. OK. Then the wire burned into again. Help
#2 Posted : Friday, April 17, 2015 5:50:52 AM(UTC)
Did you check the heater to see if it was grounded.
Below is my usual blurb about blow thermal cut-offs on the heater.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
In your case it is more likely a grounded element.
Also make sure that the heater and wire connectors are nice and clean.
If dirty/corroded/pitted electricity sees this as a resistance and causes heat as the current flows through the connection.
