smnzhkh
#1 Posted : Tuesday, May 12, 2009 5:51:59 PM(UTC)
smnzhkh
Washer is almost "dead". Motor is not working in any mode. If washer is plugged in it could be filled with water. If it is not plugged in water is not coming in.
In any case the motor is not working.
Is there a fuse on that model? I do not have a manual.
Thank you!!!
sidfink43
#2 Posted : Thursday, May 14, 2009 4:50:10 PM(UTC)
sidfink43
Ok, I am assuming that when you start the machine it fills with water, and then nothing happens.
You need to check the motor coupling, and along the way you can check the lid switch.
This video will show you how to open your machine and check the motor coupling. To check the lid switch, just by pass it by inserting a solid insulated wire with the ends exposed into the two outer holes on the plastic coupling coming from the console and leading into the cabinet.
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
When making inquiries about your model, insert a 110 in front of your model number.
Good luck and let us now what you find out. The chances are very high it is the motor coupling, which is a very inexpensive fix and the video shows you how.
smnzhkh
#3 Posted : Saturday, May 16, 2009 10:30:47 AM(UTC)
smnzhkh
I found the problem and it is the timer. I need to replace it. It kind of simetimes is working and sometimes it's not.
Thank you for your answer it was educational too.
sidfink43
#4 Posted : Saturday, May 16, 2009 12:33:49 PM(UTC)
sidfink43
Glad you found the problem, good luck with your repair and thanks for updating us. That is very helpful. And thanks for not saying I was wrong in my diagnosis. (Just don't tell anyone)
