We've had our water heater for a few years now. We've noticed that our hot water has been taking longer and longer to heat lately. What can we do to fix this?
If your water heater has a dip tube, you can try checking it to see if the cold water is finding its way to the bottom of your water heater. Loose wiring can also cause the problem. Here's a water heater inspection checklist that can help you with your problem.
if you pull the fuse out of the circuit board then the inducer starts up and the led blinks 6 times signaling an open rollout. put the fuse back in and the led stays on steady www.allmobilespec.com/
I have suffering the same problem, but thanks to stonep. Your suggestion are very useful for me. It'll work for me.
