johndrew
#1 Posted : Monday, April 6, 2015 9:06:07 PM(UTC)
johndrew
The washer stopped with 11 minutes left in the cycle during the spin cycle.
I tried to restart and it would not spin.
I removed the clothes.
Tried to a completely new cycle
It locks the door and the lock picture comes on and locks the door.
A clicking noise like the door is locking
In about 5 seconds, it will release the valve, in about another 5 more seconds it will try again and never releases the valve until I turn off the power, then it will release the valve.
There never were any error codes except when I unplugged it and got a PF code.
Water pressure is good at the machine when I disconnected the cold water hose.
I can change the cycle settings and all lights and settings are normal and change with the new settings. All lights work properly when trying other cycles.
Tried just cold water, same results, Tried just spin and same results, locks, stops after about 5 seconds then retries until I turn off the power.
No bells, like when a door is open..
After 8 hours. A loud buzzing noise sounds appears to be on bottom. It gets dimmer in about 20-30 seconds. I saw a code which appears to be db on the machine before I did anything this morning.
johndrew
#2 Posted : Tuesday, April 7, 2015 4:26:00 AM(UTC)
johndrew
I took off the back panel and also the water pump and found a quarter inside the pump. Took needle nose pliers and removed the coin. Going to reinstall and try it. Be careful of the water which will come out when the hoses are disconnected.
