Hi folks, I have the above model Sears side by side refrigerator-freezer. The clear plastic ice chute flops forward whenever the lever is pressed to dispense ice. When the lever is released, the chute gets stuck and leaves the rubber flap not sealed against the opening of the freezer. Consequently, moisture gets inside and freezes inside the freezer. It appears that there are 2 different tabs that are supposed to catch underneath the lever to hold it on. The clear plastic chute also has a prong that goes in a hole in the middle of the lever. I am looking for an exploded diagram or instructions on how to replace this plastic chute and a part number for the plastic chute. Against my better judgement, I tried to force the clips over the side of the lever and one of them snapped. Not completely off but bent. I probably need to by a new clear plastic chute but for the life of me I can't figure out HOW to put it back onto the dispener handle. Thanks! Greg [IMG]http://www.kodakgallery.com/PhotoView.jsp?&collid=47804858411.651374674211.1242502086454&photoid=355934674211&folderid=0&view=1&page=&sort_order=&albumsperpage=&navfolderid=2009[/IMG] [IMG]http://www.kodakgallery.com/PhotoView.jsp?collid=47804858411.651374674211.1242502086454&photoid=844114674211&folderid=0&[/IMG]
[IMG]http://www.kodakgallery.com/PhotoView.jsp?UV=348278907133_538624674211&collid=47804858411.435625492211.1242501591161&photoid=645054674211&folderid=0&view=1&page=&sort_order=&albumsperpage=&navfolderid=2009[/IMG]
